Doug,
I believe the config option provide_pick_message_always is the closest thing available in WF5. Set it to Yes to enable seeing the messages. They will appear at the top of the screen, though. I don't think there is a way to get the messages at the bottom of the screen anymore.
Brian
In Reply to Doug Schaefer:
This week is my first serious work in WF5 (out clients are typically
slow to upgrade), so I'm finding little annoyances that I'm sure most of
you have already dealt with.
In WF4 and older, there was an area at the bottom of the window that
would show the name of the item that was highlighted on screen and would
update with the pre-highlighting. . I'm not talking about the message
area, but I'm not sure what it was called. It was very handy for
determining what you were about to select. If I hold my mouse still
long enough, I get a tool tip pop up with that info, but this was
instantaneous.
In WF5 it's gone, how do I get it back?
Doug Schaefer
Senior Project Engineer, Mechanical
Design Central
Columbus, Ohio
www.design-central.com http://www.design-central.com
614.890.0202
Confidentiality Notice
This is a transmission from Design Central Inc, Columbus, Ohio which may
be privileged and confidential, and thus is protected from disclosure.
This message is NOT intended for transmission to, or receipt by, anyone
other than the named addressee (or a person authorized to receive and
deliver it to the named addressee). If the reader of this message is not
the intended recipient, or an employee or agent responsible for
delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution or copying of this
communication is strictly prohibited. If you have received this e-mail
message in error, kindly accept our apology and please delete it from
your system without copying or forwarding it, and notify the sender of
the error by reply e-mail or by calling 614.890.0202 (collect).
