WF5 & spacepilot
ptc-2195696
WF5 & spacepilot
I have installed WF5 & now the 1-6 buttons, fit & view buttons on the spacepilot are not responding. I have installed the lastest driver from the 3Dconnexion web site. Has anyone else had this problem?
6 REPLIES 6
It may be that it sees the new install as a totally new software, and you'll have to reprogram your buttons.
Chris Benner
Autodesk ® Expert Elite
3Dconnexion have not updated there driver to work with WF5, so will watch there site for the update.
We use Space Explorers,... seems to me we went through the same with the switch to WF4 and it was a month or two that our buttons did not work.
Chris Benner
Hi, 3D connexion have released the updated driver to run under WF5, all is back as before.
Does this fix the disabling of UNDO? I have the latest drivers and with the mapkeys file in place the UNDO function in Pro Engineer is disabled.
