Warning Message when I open Creo.
odavies
1-Newbie
This morning, when I opened CREO Parametric 3.0, I received this message:
When I clicked continue, I received a message about a 'jQuery' error and 'Script' error. When I requested for the script to stop running, I was faced with this blue screen:
Image result for your pc ran into a problem.
So, I proceeded to shut down my computer. When I rebooted my computer and opened the Creo program, I received the retrieval message again, along with the blue screen. I decided to shut down and reboot my computer. After the rebooting process, I uninstalled all Creo 3.0 files and installed Creo 4.0 files.
When I open Creo, I still get the retrieval message, but I also get a 'Warning Message List':
Clicking OK on this warning completely closes Creo Parametric.
Is anyone else encountering this issue and have you found a solution?
1 ACCEPTED SOLUTION
install Creo 3.0 and try solution mentioned in UNEXPECTED_KERNEL_MODE_TRAP following Windows 10 Creator Update - Solution...‌ discussion.
In case of Creo 4.0 ... I guess that PTC did not publish Product code for it.
MH
Martin Hanák
4 REPLIES 4
Also, the code given for Creo 3.0 is the same code given for Creo 4.0. Is this a mistake? This is the code: BK400407EDSTUDENTUNICL
MH
Martin Hanák
I tried the solution and it worked. I still received warning messages, but I was able to close those windows and continue with my work.
This message window displays usually in cases when previous Creo session crashed. If you finish Creo session using File > Exit command. the message will not appear on next Creo launch.
MH
Martin Hanák
