Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi I want the weight of the model in ProEngineer Bill Of Material created by using the repeat regions.I have added the parameter(weight) in relations and i want only that perticular parameter value to be extracted in Repeat Regions.Can anybody suggest me any
In repeate region you should select asm.mbr.User Defined then, pro-e asks for the parameter name, now enter the parameter name (weight in your case) Then update the table.
Thank Prashant But it is not working See I have added the parameter weight of which the source is Relations not the user defined so I think it is not working. Is there any other solution
