Whenever there is no space in the server the Creo Parametric 3.0 does not indicate “No Space & cannot save file” which was there in Creo 2.0, instead the file gets saved in “0”KB size as a result
ndaslaniya
7-Bedrock
we have a query in Creo Parametric 3.0 : Whenever there is no space in the server the Creo 3.0 does not indicate “No Space & cannot save file” which was there in Creo 2.0, instead the file gets saved in “0”KB size as a result after a lot of work done by the executor gets saved in 0KB and he closes the file the entire work gets lost … Please let us know if we have any solution for the same …
This seems like a potentially serious bug, have you reported it to PTC tech support?
LinkedIn
Nikhil,
Found an Article and seems issue was reported earlier and has been corrected in M030
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS188184
