Who is using Mfg. UDF's
rcordova
I wondering anyone out there using mfg. udf's successfully? I'm currently using Wildfire 5.
We have a large number of MUDF's that we use daily.
3 REPLIES 3
Hi Brian, thank you for your response! I'm interested in how you use MUDF's. Do you have tools & parameters tied to manufacturing steps? We primarily use custom trajectories, volume rough with windows (rough and finish), surface milling (sometimes we use mill surfaces or we pick directly from reference model) and last but not least drill & tap.
Hello Rick,
Yes, we have tools and parameters tied to the steps.
We are using MUDF's on custom trajectories, volume roughing (rough and finish) with a predefined window or volume, surface milling (referencing a mill surface), and large number of drilling and tapping sequences.
If you would like drop me a line and I will get back with you after the holiday. I can answer any questions you may have or I can send you some example MUDF's that we use.
