Wildfire 3.0 Sketcher Pallete
ptc-666443
How do you go about adding your own sketches to the pallete? Thanks.
The sections in the sketch palette are by default stored in the Pro/ENGINEER install directory, in the folder "text\sketcher_pallette", i.e: C:\Program Files\ptc\proeWildfire 3.0\text\sketcher_palette\ If you want this in a seperate location, you can use the config.pro option "sketcher_palette_path" To create a new section or retrieve an existing section: Save or copy the section to the subdirectory corresponding to the sketcher palette tab within the sketcher shape directory. The file name of the section appears as the name of the shape along with the thumbnail of the shape within the sketcher palette tab. To Add a Tab to the Sketcher Palette: Create a subdirectory within the sketcher shape directory. The subdirectory name appears as a tab label in the sketcher palette. Note: The subdirectory name appears as a tab label in the sketcher palette only if the subdirectory contains at least one section file, that is, a file with a .sec extension.
Thanks Andrew.
Thank you I was also looking for that piece of information.
