Wildfire 4 M100 Issue with Measure command
ptc-1641498
Thanks to Randy for confirming the problem and sending me the link to the
fix.
This is a known issue with WF4 M100:
6 REPLIES 6
FWIW, this is not recognized in my M100 as valid...
ERROR - C:\Documents and Settings\John Dugan\Wildfire4\config.pro, linenum 11: Keyword 'ENABLE_K01_ANALYSIS' is not valid.
Anybody know if this is a problem on M090?
If not I will roll back.
While it wasn't a problem on the smaller assemblies, I'm on a bigger one
now and measuring is unusable in M100. 😞
Walt Weiss
Hi
M90 M 92 are both fine.
Best regards
Stephen
I think the config.pro option should be "enable_ko1_analysis no" as listed in TAN 145709, ko1 vs. k01.
Best Regards,
Don Duncan
This did not work for me at all (either spelling) I received the std.out
file stating invalid no matter how I spelt it.
Does anyone know of another work around?
FYI I got an email from support saying that this issue would be fixed in
M120 (12/01/09)
Chris
