Wildfire Datecodes
ArisTroulis
Wildfire Datecodes
How can I see what is changed in every new datecode update from the previous one. Just to make sure if its worth spending time to download and upgrade. Thanks
Use the link below. You can configure which releases you want to see and compare against another. Eric http://www.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
Thanks Eric
