Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I need a solution for a Jave update issue we are having. We keep being prompted to install the latest Java when downloading objects from Windchill. We use lotus notes which uses a different version of Java than PDMLink.
