Work online and offline simultaneously in creo 3
hvyas
Dear users,
In creo 2.0 after opening two different creo 2.0 and keeping one online and keeping other offline from windchill workspace we were able to work on two different parts.
But in creo 3.0 I am not able to work online in workspace and offline in local drive simultaneously. Let me know if there is any solution to it.
thanks in advance
Marco_Tosin
(To:hvyas)
MartinHanak
(To:hvyas)
maybe if you define two Creo launch commands and set different variable values (for example PTC_WF_ROOT, PTC_WF_CACHE, ...) in their psf files then you can launch Creo 3.0 two times and these two session will be independent.
Note: I never tested this tip.
MH
Martin Hanák
