I was wondering how to use the Bookmarks under the Your Stuff drop down next to one's name up by the top right of the page.
I wanted to book mark a particular discussion: Tips for Text:
http://communities.ptc.com/message/182709#182709
How do you actually create a bookmark with the drop down, and can you use it for discussion or something else?
Thanks, Dale
This drop-down menu is only for managing your already stuff, or at least looks like that. If you want to bookmark specific topic, on your right there is this blue-background menu Actions, where you have stuff like Report abuse, View as PDF and Bookmark this. As you can guess, the last one bookmarks your current topic and then, using drop-down menu Your Stuff, you can access it later.
... and now it shows up as a book mark in my "Your Stuff"
