ampersand in note
StephenW
ampersand in note
Okay I searched the archives and didn't get anywhere.
I would like to add an ampersand (&) to a note but since it is a special character I seem to be having problems making it happen. Is this possible?
I want my note to look like the... TEST CAP, C&K, instead of ... TEST CAP, C AND K.... Any hints?
StephenW
(To:StephenW)
Actually it's in a symbol, not a note. I can make it happen in a note but not a symbol...
Apr 20, 2009 09:08 AM
StephenW
(To:StephenW)
Well so far I've tried the following in my symbol:
putting a space on both side... C_&_K ....didn't work
putting the & in quotes
In Reply to
StephenW
(To:StephenW)
putting the & in quotes (double and single) .... C '&' K ... C "&" K ... didn't work
putting in double &&... C && K ...didn't work
using alt 38 or alt 038 .... didn't work
No luck yet for getting the ampersand & in my symbol
In Reply to
Have you tried typing it twice?
Thank you, Jim Flores
Mech. designer/CAD admin.
Clinical Care Systems
Philips Healthcare
2271 Cosmos Court
Carlsbad, CA. 92011
StephenW
(To:StephenW)
The symbol I am trying to insert in my drawing uses variable text for this field and it's a completely open field as far as it doesn't have just a few potential entries.
As Stefan suggested, I was able to create a parameter (i used a drawing parameter that I called "ck") and then I used it in the symbol. It worked. Not the cleanest of solutions, but it was a solution...
For the variable text in my symbolI used... &CK:D .... I defined a drawing string parameter called ck and set the value to TEST CAP, C&K.
That's my best solution so far, I appreciate all the help.
Steve
In Reply to
