hi,how could i close annotation element display when i start pro-e?
Harrison,
you can set config.pro option model_note_display to yes or no. Or you can switch the setting using UI.
Martin Hanak
Harrison,
Martin Hanak
thank you very much.
THANKS FOR YOUR APPLY,BUT I USE PRO-E 5.0,COULD YOU PLEASE TELL ME WHERE TO FIND PARAMERTIC OPTIONS?
DISPLAY_ANNOTATIONS yes/no
THANKS FOR YOUR REPLY.
