Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Ilink3.3 M022 Win2k What is the trick to getting "ilink_report_log < input" to work? I have provided the necessary text lines in the file "input" based on ptc support site verbiage. Get message "....file not found...." after hitting return. Thank you in advance... jim
