I thought I saw in that in Wildfire 2.0 you could save back to an
earlier version of ProE such as 20...
567
Views
by
bobreetz
1035
Views
| I am working on the Company Logo with lotsa Splines. I'm creating it as
a Sketch (.sec suffix) so th...
1035
Views
Or HELP, HELP CENTER, MENU MAPPER, among the other tools. -- Rui
"Sukhesh Shetty" wrote in message
493
Views
by
Bill_Kunz
1006
Views
| Thanks to all, I got about a dozen answers in 15 minutes.
1006
Views
Sorry about the message overload, the prev message had no subject line
501
Views
  Hello to all, Can any one help me how could I modify the View
Breakout position. I had tried t...
515
Views
I have done this in the past but can't remember the correct techniques.
Can someone please describe ...
645
Views
I am trying to create push button names read from some other file other
than menu_fil.mnu. I am tryi...
623
Views
by
CHARLIEWENNING
1 Reply
818
Views
| Just curious as to who the instructor is. We used the MDSI software back
in the 70's and I knew a lo...
1 Reply
818
Views
by
unknown1
569
Views
| We've got a winner. Sean (Ancient Pro/E user since Rev 9) sent this
link. This explains it all: http...
569
Views
1 Reply
897
Views
| PTC is changing the way that they name their build releases. M stands
for a maintenance release. The...
1 Reply
897
Views
Mechanica Users, I can not remember the setting to get FEM Mode to work
in Pro/Foundation. I have a ...
816
Views
by
PeterBrown
1551
Views
| I'm not aware of any old version of Pro that cannot have its files
opened in the latest version or P...
1551
Views
Hello All, Might anyone know if you can attached an excel file and use
it with repeat regions. If so...
640
Views
by
unknown1
544
Views
| I've had some requests for the zip file and I managed to get it smaller,
so here it is... It has the...
544
Views
by
marty_hall
1322
Views
| Is there any way to import say a JPG or any other files into Pro and
then use them for references to...
1322
Views
by
drew007
586
Views
| I have an Intellimouse Explorer with 5 buttons. I have set the buttons
to Ctrl and Shift in the conf...
586
Views
Hello All !! I was adding menu hot buttons (Tool/Customize Screen) and I
was dragging out pull down ...
657
Views
I know some of you have probably created your own line styles. My
question is can you create a line ...
624
Views
From time to time we send models to customers and vendors. Is there a
way to add a "proprietary info...
635
Views
by
unknown1
545
Views
| dear pro/e users, in trimetric view we are seeing top,front and right
side of model but i want to se...
545
Views
by
ddills
1 Reply
853
Views
| Is there any easy way to make a dxf 3d file to a solid or surfaces in
pro. Is there a software I can...
1 Reply
853
Views
---------------------------------------------------------------- Hi-Tech
Gears Limited, Gurgaon, Ind...
583
Views
575
Views
2443
Views
| Haven't had a single message from the Model list since the new service
went into effect. Anyone out ...
2443
Views
| Subject | Author |
