break xhatch lines for text
JLG
Is there a way to break cross section lines around some text? See the attached picture.
FYI, I'm using WF4.
Thanks!
Janet Grove
John Deere Power Systems
mpeterson
(To:JLG)
Yes. In the Note Properties box check the box for Break crosshatching in the
lower center of the dialog box in the Note/Dimension area.
Mark A. Peterson
Sr Design Engineer
Igloo Products Corp
ujassuthar1
(To:JLG)
Hello Janet,
This is very impressive question.
Just go drawing Option and Typedef_xhatch_break_around_text. Default Value is No..
Change the value YES and once again give the Dimension Or Write the Text.
Ujas Suthar
