can anybody convert brocken view to previous view
ptc-1428410
hi i coneverted a view to brocken view i want to break in horizontal direction but i got in vertical direction i want to modify how can i?
6 REPLIES 6
hi there, change it back to a full view then try to make it right regards, vb
Not applicable
(To:ptc-1428410)
You can select vertical or horizontal only if the view is general view. But a I think broken view cannot be removed. only thing you can do is delete that view and place a new view.
ptc-1373684
(To:)
hi there, just tried by selecting the break line and change it from H to V and viceversa, so it works like this.
hi there, of course you're right...I was thinking about proe 2001. I may say that the H/V breaking direction depends on the projected view creation direction. So it looks to me that the mainview has to be oriented in such manner that the broken view creation to be suitable...Or maybe create the broken view on the proper projected view. regards
