closed corners
MichaelVHubbard
closed corners
This may be a tough to explain, but here goes:
When trying to create a closed corner, as explained in the PTC link below, I
have had no problems in the past.
http://www.ptc.com/cs/cs_23/howto/smd_ccwl/smd_ccwl.htm
However, now I have a scenario in which to create the closed corner as
described, I must align my flat wall sketch to the inside of an existing
"swept" wall. For some reason it will not create the closed corner with the
swept wall.
What is it about a swept wall that prevents this.
best regards,
ProE 2001
Michael Hubbard
0 REPLIES 0
