could some one please expalin the difference between the two different shrinkage formula's in Pro/Engineer.
(1+S) and 1/(1-S)?
hey sumeet..how are you?....
i am not that wise dude.....i read that...did not understand...the second one and then read the first one again...and now i am confused..it would help if you could elaborate with a example.
thanks.
S is in percentage when you scale the whole model so 1+s s=10% s,viz 0.1 1+0.1=>1.1 x model size
1+s will enlarge the model size apply shrinkage already and 1/1-s will reduce the model size ( assuming s is positive in both cases)
