editing tables
ptc-5493477
editing tables
Is there a way to remove rows/columns from tables? I see how to add, but not remove.
Thanks!
Ok, Select table row/column > RMB > DeleteTable.png
5 REPLIES 5
Are you referring a repeat region table or standard table?
If it is a repeat region you cannot remove row, however you hide the row in repeat region using filters.
standard table
works! Thanks! selecting is a little sensitive, but otherwise ok.
Using "query-select" instead of the (lame) pre-highlighting allows you to easily scroll thru options like cell, row, or column. It also allows MUCH better selection of references to prevent bad parent-child relationships.
