error in opening PTC cero files in proe 4.0
ptc-5439671
dear,
i have few prt and asm files made in PTC_Creo1.0 version. i want to open those files in proe 4.0. But by doing so i am getting an error that "<fille name> can not be retrieved". please tell me how can i open these files in proe 4.0
thanks
Creo files are not backward compatible. There is a tool called Granite that will help you.
It is easiest to import a STEP file if you can get the original file converted.
http://www.ptc.com/product/creo/3d-cad/parametric/extension/granite-interoperability-kernel
1 REPLY 1
