Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Lyle This can happen if there are other oracle programs installed. We sometimes get an issue if the smarteam (oracle ) based is used before intralink is started.
Ian Turner
CAD Manager
Cobham Mission Equipment
Preview file
12 KB
