extrusion with grooves
amedina
So I was looking at some ideas for packaging some batteries, when I came
across this one. I was wondering if anyone had a supplier for this type
of extrusion. I need a flat piece of aluminum that I can screw to from
the bottom and the top. Any other ideas would help. Do you know of any
supplier that might have sample models? I know that most will have
standard extrusions that they use.
Alfonso Medina O.
Mechanical Engineer
Tel: 858-413-1720 x794
Fax: 858-413-1733
ISE Corporation
12302 Kerran Street
Poway, CA 92064
0 REPLIES 0
