Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I just started evaluating GRANITE and I have some questions about the API. I'd also benefit greatly from reading about other people's experiences with GRANITE. I realize this is not the right place for GRANITE posts, but I'm hoping somebody can point me in the right direction. Thanks, Cory
I went to the free downloads, downloaded the file, printed out the info and followed the instructions, it went well. It will load wildfire 4 files in wildfire 3 except mfg files.
Just to be clear- the GRANITE install went smoothly for me and I have been able to do some simple stuff including generating triangle strips for rendering by OpenGL, but I'm not sure about some of the more complex stuff (like the boolean operations).
