Creo 2 loads on a laptop that meets minimum spec BUT I can not close out the browser to get to the work area and start work. The IT revs at work have tried a number of things found in support documents but still no joy. I need to complete a number of pre-course tasks for a course on Wednesday this week so would appreciate a prompt reply!
One of these should work for Creo:
I don't see this option in config.pro so it is likely part of the toolbar settings which is saved for all sessions even after upgrades are installed.
And welcome to the forum, Peter!
Cheers Antonius,
I've quickly tried the toggle icon and will try the option settings between classes!
Many thanks
Peter
Hi- I've set the options toggle as shown, which has got rid of the browser but now I see the desktop and now "work" surface!..... arrggggghhhhhh
