The core node you are trying to access is permanently deleted.
how to get cloud point data of imported stl model in pro e
Once you get it there, I am not sure what you are going to do with it, because from an earlier discussion, it doesn't look like it is editable.
Thanks, Dale
We heard that from cloud point data we can modify mesh such that we can change triangular mesh(stl) to some other format. thanks for your concern
I think the "Restyle" module is what you are looking for. Here is a video on creating surfaces from facet models:
