hole files incomplete
lococnc
When did PTC stop filling in hole information in the .hol files?
Starting at 9/16 they do not have any information for clearance holes.
Why?
BenLoosli
(To:lococnc)
My WF2 hole files (2005) are also blank for clearance hole information, so it has been a while.
Easy enough to modify and add what data you need.
I have often modified the tables for the drill size that the shop wants rather than use the PTC supplied data.
Thank you,
Ben H. Loosli
USEC, INC.
pdkoren
7-Bedrock
(To:lococnc)
When I did a corporate setup, I also edited the hole tables... I eliminated all but the standard coarse and fine thread versions of both the standard and iso styles... That way I didn't have someone mistakenly using a hard to obtain thread...
just a thought...
Chris3
(To:lococnc)
It's because the information comes from the Machine Handbook (table 4 "Tap Drills and Clearance Drills for Machine Screws with American National Thread Form")
The table in the handbook stops at ½ inch.
Christopher Rees - Mechanical Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Rd, Danbury, CT 06770 U.S.A.
