here how to set units permanently in creo as mmns or inlbs
Kishor,
There are unit base template files in Creo, you can use one as per requirement.
When creating a new part, uncheck Use Default template and browse to one.
If you want to set any specific template part as default, use config option template_solidpart.
Hi Kishor,
Does the information in last reply help you?
