please tell me how to start advance framework in ptc creo 2.0/
You need to set option afx_enabled to yes in your config.pro and restart Creo. After restarting you should be able to access Framework tab from the assembly level.
also Advanced Framework Extension option must be checked during installation.
Look, whether Creo2_LOADPOINT\Creo 2.0\Common Files\Mxxx directory contains efx subdirectory.
Martin Hanak
hi ! what to do if i dint install the first time? ..other than reinstalling again....tnk u
from my point of view reinstallation is the only reliable procedure
MH
tnks...i tried it still not wrkng...i use creo parametric 2.0 M010........efx file is installed in the m010 file and also i m trying in asembly mode only....why isnt it wrkng?
1.] check if your config.pro file contains options ... afx_enabled yes
2.] create new assembly, then publish picture of current Creo window ... I need to see ribbon interface
MH
hi its over here ....the framework tab isn't displayed
Uttam,
Advance framework is available in assembly mode. Create an assembly to check tab for Advanced Framework
Uttam,
Did you manage to work with AFX?
