how to start framework in creo 2.0?
ujadav
please tell me how to start advance framework in ptc creo 2.0/
9 REPLIES 9
You need to set option afx_enabled to yes in your config.pro and restart Creo. After restarting you should be able to access Framework tab from the assembly level.
MartinHanak
(To:ujadav)
also Advanced Framework Extension option must be checked during installation.
Look, whether Creo2_LOADPOINT\Creo 2.0\Common Files\Mxxx directory contains efx subdirectory.
Martin Hanak
Martin Hanák
hi ! what to do if i dint install the first time? ..other than reinstalling again....tnk u
from my point of view reinstallation is the only reliable procedure .
MH
Martin Hanák
tnks...i tried it still not wrkng...i use creo parametric 2.0 M010........efx file is installed in the m010 file and also i m trying in asembly mode only....why isnt it wrkng?
1.] check if your config.pro file contains options ... afx_enabled  yes
2.] create new assembly, then publish picture of current Creo window ... I need to see ribbon interface
MH
Martin Hanák
hi its over here ....the framework tab isn't displayed
Mahesh_Sharma
22-Sapphire I
(To:ujadav)
Uttam,
Advance framework is available in assembly mode. Create an assembly to check tab for Advanced Framework
Mahesh_Sharma
22-Sapphire I
(To:ujadav)
Uttam,
Did you manage to work with AFX?
