how to update Creo ???
Good points, David.
I do not think I have experienced any problems with Thumbviewer and Creo Agent across builds, but playing safe is recommended.
I even use the same local Windchill cache area between builds with apparently no error related to it. I guess mixing releases is more critical.
Creo Agent is also needed if you are using Precision LMS eLearning linked with Creo.
/Bjarne
