is fujitsu celsius w530 compatible for creo 3.0
rmore
is fujitsu celsius w530 compatible for creo 3.0?
VladimirPalffy
(To:rmore)
here you can find Platform support (Hardwere notes) for creo Parametric 3.0 - http://www.ptc.com/File%20Library/Product%20Families/Creo/Shared%20Files/Creo_2_0_Hardware_Notes.pdf
Vladimir
Best Regards,
Vladimir Palffy
Depends on the version/configuration, I'd say. You can check hardware requirements here (it also contains list of supported/certified workstations): http://www.ptc.com/File%20Library/Product%20Families/Creo/ptc-creo-hardware-notes.pdf
EDIT:
ninja'd by Vladimir
