is it possible to change the colour of the ribbon ui in creo 3.0
garytinker
hay guys and girls,
is it possible to change the ribbon ui colour? this new colour pallet is bright as in neon bright. compared to the new 2015 autocad ui its like looking at the sun.
basically I'm having a lot of trouble finding the buttons amongst all of the white especially now that button colour has been washed out as well.
for now ill just whack the gamma down to almost nothing
id rather not make a hundred macros with more contrasting icons but i will if i have to.
so can we change this?
1 ACCEPTED SOLUTION
Unfortunately you can't. You can change the colors inside graphics window, but color scheme for the rest of interface is fixed white.
5 REPLIES 5
garytinker
(To:LukaszMazur)
yea thats what i thought. oh well
Unless this install option gives you some control...
Creo 3.0 Download is Ready
See Matt's reply with image
http://communities.ptc.com/servlet/JiveServlet/downloadImage/2-250257-75975/450-337/creo3-1.JPG
Antonius,
PTC Creo UI Editor enables developer of Pro/TOOLKIT application to debug UI of custom dialog boxes displayed by the application.
Martin Hanak
Martin Hanák
Oh
