is it possible to unbend a rod .
ptc-136270
a handle was make with 3/8" rod and i want to give the bend and the lenth of the rod.
As per my knowledge I do not think we can unbend rod.But if there is any way.Please let me know too. Thanks in advance!
Guy, Do you have a Datum Curve running along the center of your bent rod? If so, you can simply measure its length to get a close approximation, unless you have strange bending conditions. David
