libraray parts available in pro-e or not
unknown1
Hi every body
Is there any library parts created default in pro-e like the fastners
srews bolts etc..
So it would be easy to retrieve while doing .
If it is available please let me know
Thanks in advance.
With Regards
T.Madhava Rao
Ask your reseller or PTC for the BASIC LIBRARY on CD.
At the bottom left of this page
Thxs to all
Those who replied I got the cd of basic library.
With Regards
T.Madhava Rao
900cat
(To:unknown1)
SmartLibrary for Pro/ENGINEER
(http://www.sigmaxim.com/html/smartlibrary.html) is the automated
alternative to standard Pro/E libraries and is 5-10 times faster. It
TOTALLY ELIMINATES the problem of hole misalignments between parts as well
as problems of screw-thread mismatches by doing the repetitive, error-prone
feature creation (holes, counterbores, threads, etc) for you. SmartLibrary
is Intralink compatible and many people use it for their existing library
parts (even nested family tables), although a library of fasteners is
provided with the software.
When a fastener such as a screw is selected, all the associated hardware
(washers, nuts, etc.) and necessary features (counterbores, drilled holes,
threads, etc) are automatically assembled and created. Features are created
at PART level and there is an option to maintain references to the assembly
for position, or break the references and create an independent dimensioning
scheme for the features within the part.
The quick preview GUI provided with the software makes selection of the
correct size fastener, with associated hardware, a snap. SmartLibrary also
promotes standardization of fasteners, and custom parts and assemblies
within your company.
Sigamxim is a PTC software Partner. If you want more info on this product
please contact us at: http://www.sigmaxim.com/html/contact_us.html
Craig Therrien
