mass does not update
FrankSiano
amount=pro_mp_mass relation does not update.
Mass properties report lists 17.34 lbs, amount param shows 34 lbs
material =  steel
to re-compute mass properties, click File > Prepare > Model Properties > change (in Mass Properties row) > Calculate (in Mass Properties dialog box).
Copied from Re: Center of Gravity is not changing
MH
Martin Hanák
6 REPLIES 6
BenLoosli
(To:FrankSiano)
You need to calculate the MP from the File-Prepare material menu, then regen to update the parameter.
This was discussed last week.
MH
Martin Hanák
Hi Frank,
I hope replies in this post help you. Kindly mark the appropriate reply as correct answer for the post.
Yes the intructions work. the bad news is that if you have parts in a family table you have to open and repeat this for each one!!!!!
BenLoosli
(To:FrankSiano)
No you don't. Open the generic and add a pro_mp_mass column (or your parameter that is set to pro_mp_mass) to the FT, then verify the FT and all of the weights are updated. Checkout the generic and all instances and check them back in.
I uploaded test model created in CR2 M070. It contains parameter W included in family table and driven by Post Regeneration relation W=pro_mp_mass.
MH
Martin Hanák
