Is there a place where you can get common steel and ductile material files to use with Pro & Mechanica without having to create your own? Any resources on the web?
Thanks in advance,
Mike Johnson
Senior CAD Designer
Carlisle Industrial Brake
812-334-8797
<u>-</u>
***if you receive an attachment with extension .cib it is a zip file. Rename the extension to .zip to open***
