new text editor
Is there anyway to go back to the creo2 text editor style for notes?
I would like to see what the limitations are with the new editor. It would be good to submit support cases if you are having trouble duplicating what you once did before including "click counts". Maybe PTC can figure out what they need to enhance the future versions. This is a 1st cut implementation so there are bound to be required improvements. If we can get ahead of this with a comprehensive blog or discussion, this should be easier to make recommendations or at least show where the painful operations are.
Unfortunately, there still isn't a wide adoption of Creo 3.0 at this time. You courageous pioneers are our only insight!
Joe, can you tell me exactly what you are trying to do? Is there something you can't do or does it simply take more steps to do it?
SYNDAKIT15-MoonstoneAuthor
yes, I am trying to create a specific mapkey that i can't get to work; and I'm guessing its because of the new text editor.
I'm trying to replicate a mapkey that i created in creo2 for creo3, but I'm not having any luck.
Below is the mapkey that works in creo2
mapkey u @MAPKEY_NAMESMART_MARK;@MAPKEY_LABELSMART_MARK;\
mapkey(continued) ~ Command `ProCmdDwgCreateNote` ;#MAKE NOTE;#NO ARROW;@PAUSE_FOR_SCREEN_PICK;\
mapkey(continued) @PAUSE_FOR_SCREEN_PICK;&PTC_COMMON_NAME:ATT;;#DONE/RETURN;
when i try to replicate the same mapkey it stops when the text is supposed to fill in automaticly
Yes, something seems weird. For starters the ":ATT" doesn't seem right.
The captured mapkey is also VERY different.
Wildfire 5
mapkey(continued) ~ Command `ProCmdDwgCreateNote` ;#NO LEADER;#MAKE NOTE;\
mapkey(continued) @PAUSE_FOR_SCREEN_PICK;&PTC_COMMON_NAME;;#DONE/RETURN;
Creo 3 (typing in "&PTC_COMMON_NAME")
mapkey(continued) ~ Command `ProCmdDtlInsFreeNote` ;@PAUSE_FOR_SCREEN_PICK;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 16777216 `Shift`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 20381734 `Shift+7`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 5242960 `P`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 5505108 `T`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 4390979 `C`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 23003231 `Shift+_`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 5177423 `O`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 5046349 `M`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 5111886 `N`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 4259905 `A`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 4522053 `E`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 851978 `Enter`;\
mapkey(continued) ~ Move `main_dlg_cur` `NoteEdit` 2 24 24;\
mapkey(continued) ~ Move `main_dlg_cur` `NoteEdit` 2 25 25;
Creo 3 (pasting from the clipboard)
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 33554432 `Ctrl`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 39190550 `Ctrl+V`;\
mapkey(continued) ~ Command `ProCmdEditPaste` ;~ Move `main_dlg_cur` `NoteEdit` 2 0 23;
Something I definitely didn't expect was that this paste from the clipboard is dynamic. The contents of the clipboard are not captured in the mapkey. Instead, every time the mapkey is run the current contents of the clipboard are used.
I'll keep working on it....
Joe,
I have found Text Editor command. See attached picture.
Martin Hanak
This is not the old editor. For me it just opens notepad!
Tom & Martin,
What is that word that we Creo users use, to say that we have found a workaround? Well anyway I have found a (insert workaround word), for this issue.
Although not a solution for the previous problem; it seems to be working for now.
preparations @ PART LEVEL ---> EFX_ITEM_NR=[PARAMETER]
mapkey 77 ~ Command `Positionsnummer_erzeugen` ;@PAUSE_FOR_SCREEN_PICK;\
Let me know what you guys think.
Pro|WorkAround^tm
(trademarked by all Pro|Engineer and subsiquent issue users of PTC parametric modeling software, 2013, 2014, etc.)
delightful
