parameter name
unknown1
parameter name
Can you change the parameter name?? While creating the parameter, I was
able to rename it. But, once I ok'd and went back I wasn't able to rename
the parameter. I had to go and delete the parameter and recreate it.
I've searched the knowledge base and found no results.
Christine
0 REPLIES 0
