Hi all!
is there a way to sepparate drw publishing from asm/prt? Our cadworker gets overwhelmed with cad doc publishing, so thinking of different ways to make use of multiple cadworkers.
Thank you,
D
In Reply to Dmitry Ushamirsky:
Hi all!
Thank you,
D
So, the reason i need to separate drw from asm and prt is that we are publishing drw to pdf using Adobe LiveCycle. If I just create another cadworker, than I will need to buy another license of LiveCycle. Trying to avoid doing this.
