"Commands Not in the Ribbon"
dgschaefer
Creo 2, M040
I like the nice command search tool, it's handy.  Today I went searching for 'mapkey' and find that it's under 'Commands Not in the Ribbon'.
My question, if they aren't in the ribbon, where are they?  Is the only way to access the 'mapkey' command through the search tool?
LinkedIn
If you go in and customize your ribbons you can add them but otherwise you are correct in only accessing them from the search bar.
Andy Hermanson
Engineering Design Applications
tel 605.275.1040 x51114 mobile 605.951.0168
website www.daktronics.com
File > Options > Environment > Mapkey Settings
Thank you Brad - I was wondering exactly the same thing, having had a quick play with Creo 2 last week (jumping straight from WF4).
It's not entirely helpful to just say "not in the Ribbon"...
Jonathan
