We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
"Dual Dimensioning" for only a couple of dimensions
sstavos
Wildfire 4.0 build M060
I only need dual dimensioning on 2 or 3 dimensions, when I change the "dual_dimesioning" all dimensions change.
Is possible to change a select number of dimensions?
Steve
0 REPLIES 0
