regeneration failure in mfg model
ptc-982474
When I tried to open the previously created and checked in (in windchill) mfg model. The regeneration failure occurs and it says "invalid tool id: no such tool in database". I created this document with wildfire3 M090 & checked in windchill8 database. Now I am trying to open it with wildfire3 m110 and windchill9. Pls clarify. Thanks
Selvakumar, This may have nothing to do with rev's of Pro and Windchill. Do you have a search path set up for your tools using the config option pro_mf_tprm_dir? David
