skeletons
norwood
skeletons
ok gang, heres the ?
say i have a assy XXXX and i insert a skeleton. i have 2 sub assys YYYY &
ZZZZ (each one has serveral detail parts that feed into them).
my ? is i had a co-worker tell me on the YYYY & ZZZZ insert the skeleton
from XXXX. o.k. when i do this do i assemble YYYY & ZZZZ using the assy dtms
from those subs are do i use the dtms from XXXX that i inserted with the
skeletons.
i'm trying to avoid global references. please help. POINT MAN DOWN!!!
thanx
0 REPLIES 0
