sketch symmetry
AraviK1
sketch symmetry
Hi folks,
Is it possible to place a sketch in symmetry with the reference of centre line?
Not by manual adjustment. I am looking for some automatic symetry option to place a sketch.
let me know if any option there or not?
Aravik
AraviK1
(To:AraviK1)
Thanks folks..
Got the solution.
AraviK
9 REPLIES 9
AraviK1
(To:AraviK1)
we can do one thing for this.
Copy the sketch---->
Paste the sketch---->
Now we can fix the centre of that sketch with centre line or point.
But this is not a direct solution. right?
aravik
dgschaefer
(To:AraviK1)
You can change the text properties to be center jsutified. Tha places the anchor in the middle of the text string.
LinkedIn
AraviK1
(To:dgschaefer)
Thanks Doug.
I tried this but its not norking.
Can you suggest me that in clear steps if you can.
AraviK
dgschaefer
(To:AraviK1)
It's an option in the dialog box when you initially place the text. I believe that you can access it when right clicking on the text and selecting properties. I don't have the time to dig into it at this point, dig around and you should be able to find it.
LinkedIn
James62
(To:AraviK1)
I'm guessing you are on WF5, so I've got no idea where I would look for these in menus there, but in Creo 2 it goes as:
Select the sketch feature --> Model tab --> Paste Special --> Adv reference configuration --> Pick references you need to change
or
Select the sketch feature --> Model tab --> Operations dropdown --> Copy in menu manager --> and then it's go figure by reading the command line.
Did I just call it a command line?
AraviK1
(To:James62)
Thanks Jakub,
Yes working On WF5.
Thanks for your suggestions 🙂
AraviK1
(To:AraviK1)
Thanks folks..
Got the solution.
AraviK
You can uncheck the "Place aling curve" option.
Also note the Kerning option which works for some fonts.
AraviK1
(To:TomD.inPDX)
Ok PlatinumAntonius .
AraviK
