symbols inquiry
kmitchell
symbols inquiry
Does anyone know what the entry is to produce the equal to or greater than and equal to or less than symbol within a note?
Krystal
PTC produced a TPI 133951
Edit the note properties to include '@#' before and after the character '>'. (For Example: Test @#>@# note)
Now to change the font of character '>', select the note and move the pointer over the character '>' right click on it and select Text
Style, change the font to 'Cal_grek'. This will show the character as desired.
<u>I tested this with Wildfire4 M110 and found it works quite well.</u>
In Reply to Krystal Mitchell:
Krystal
Larry H. Smith
IT Engr Analyst
