toleranc
ptc-1232746
toleranc
if i want to show plus 0.05, plus 0.03 where is the option in pro/e
I believe it is in drawing options and is called tol_display.
if you want plus 0.03 in lower enter -0.03 in lower box.Automatically taken +0.03
You may try this: Tools>Options>tol_display>yes>Add/Chang Tools>Options>tol_mode>nominal>Add/Chang Back to the Model Double the feature you need to show. Right click the mouse and choose property. In the dialog block change the Tolerance to Plus/Minus In the Minus value type -0.03. Good Luck,
