What's the fastest way to transform points read by a topographic station to a solid (a concrete/metal structure of a building)? (pro/e WF4)
thanks
Hi
With EFX you can create metal beams from point to point. But for concrete I really do not know.
Just telling you the way I should begin.
Hopes this helps you to start.
Season's greetings
Chris
The Reverse Engineering Extension likley has to tools you need,,,
http://www.ptc.com/products/creo-elements-pro/reverse-engineering
This module is intended for use with point scans.
