Hi Everybody,
Has someone already met problems with the fonctionality "undo-redo" in creo2 which doesn't work ?
Thanks four your tips..
regards,
Stéphane
I don't think every action can be undone, but I'm not sure what things can't.
Also, I believe that activating the window resets the undo list.. Once you activate the window, undo and redo will not work. There are other actions that do the same, but I don't recall what.
We had issues with undo/redo greyed out but this was due to Pro/Program items in the start parts (see CS153272 in tech support)
Description |
Applies To |
Cause |
Resolution |
